configure dns cache analytics [add | delete] protected-client
configure dns cache analytics [add | delete]protected-client [client_ip netmask | ipNetmask] {{vr} vr_name}
Description
Configures the protected client list for the Domain Name System (DNS) cache analytics for the virtual router (VR).
Syntax Description
dns Domain Name System.
cache Specifies configuring DNS cache.
analytics Specifies configuring DNS cache analytics.
add Specifies adding to the protected client list.
delete Specifies deleting from the protected client list.
protected-client Specifies configuring the protected client list.
client_ip Specifies the IPv4 network address of the protected client.
netmask Specifies the IP address netmask of the protected client.
ipNetmask Specifies the IP address/mask length of the protected client.
vr Specifies the VR.
vr_name Specifies the VR name. If not specified, the VR of the current command context is used.
Default
If not specified, by default the VR of the current command context is used.
Usage Guidelines
Administrators can use this command to restrict the collection of DNS analytics for a protected client. When you configure the client IP subnet in the protected list, DNS queries from configured protected clients are erased from the analytics database and future queries are not stored.
The following example adds the client at IP address 192.168.3.3 on VR-Default to the protected client list:
# configure dns cache analytics add protected-client 192.168.3.3 255.255.255.255 VR-Default
or
# configure dns cache analytics add protected-client 192.168.3.3/32 VR-Default
The following example adds the subnet 192.168.3.0 on VR-Default to the protected client list:
# configure dns cache analytics add protected-client 192.168.3.0 255.255.255.0 VR-Default
or
# configure dns cache analytics add protected-client 192.168.3.0/24 VR-Default
The following example removes the client 192.168.3.3 on VR-Default from the protected client list:
# configure dns cache analytics delete protected-client 192.168.3.3 255.255.255.255 VR-Default
or
# configure dns cache analytics delete protected-client 192.168.3.3/32 VR-Default
This command was first available in ExtremeXOS 30.3.
Platform Availability
